HP M477FWP reports jam in output bin
  • compsos
    • Nov 2008
    • 22
    [Jamming] HP M477FWP reports jam in output bin
    Hi
    Examination of the paths and can not find any paper remnants anywhere. But the message will not go away. This makes the printer useless. The printer inside is very clean.
    Has anyone else seen this issue on this model? Where is the sensor that triggers the error?
    Thanks.
  • techie0419
    • Apr 2017
    • 36
    Re: HP M477FWP reports jam in output bin
    I haven't seen this error specifically. All I can think of is the black flap that shows whether the output tray is full might be out of position...but then, I'd expect to see a message saying the output tray was full, rather than jam in the output tray.
    • compsos
      • Nov 2008
      • 22
      Does anyone have a service manual on this unit? Before scrapping it would like to test the sensor itself.
      Otherwise suspect it is a logic/board failure. HP are not being very forthcoming in assistance.
      • Lance15
        • Jun 2015
        • 1073
        It looks like the Output Bin Media Full sensor is in the fuser.
        Duplex; (110-127V) RM2-6418-000CN
        Duplex; (220-240V) RM2-6435-000CN
        Simplex; (110-127V) RM2-6431-000CN
        Simplex; (220-240V) RM2-6436-000CN
        • compsos
          • Nov 2008
          • 22
          Solved Re: HP M477FWP reports jam in output bin
          Thank you Lance15
          It was in the fuser. I can not imagine how HP thought end users would be able to clear a jam stuck inside the fuser.
          It was not even visible until the fuser could be pulled out.
          And the sensor is at the back of the fuser but again not visible until both sides and the rear covers are off.
          • techie0419
            • Apr 2017
            • 36
            So much for easy preventative maintenance, nearly stripping the machines down to the frame just to change the fuser. I miss the 4200/4300 series. No tools required for PM kit.
            • Lance15
              • Jun 2015
              • 1073
              This series is the middle of the road series. Easy on the checkbook up front, but, repair costs can hurt.
