HP DesignJets 500 - system error 21:10
  • fdmarty
    • 18
    [Error Code] HP DesignJets 500 - system error 21:10
    Hi everyone! I've this error code 21:10 on the HP 500...
    I don't really know nothing about this machines...
    What can I do?
    Thanks for help!
    • 22801
    Re: HP DesignJets 500 - system error 21:10
    What can I do?
    Thanks for help!
    get the service manual
    • nmfaxman
      • 1703
      HP DesignJet 500 - system error 21:10 - Google Search
      • Lance15
        • Jun 2015
        • 1073
        If I remember, this is due to a failure of the service station fan. The first thing to try is to update the firmware using a parallel cable. You'll have to put the plotter into the emergency firmware update mode. Like that website says because the plotter wont come to ready. The latest firmware does not check for the fan in order to come to ready. If you can get the firmware updated, you should be done. The fan isnt necessary for use. If you cant get the firmware updated, you'll need to replace the service station. Have run into this code a couple of times. Sometimes I could get the firmware updated, sometimes I had to replace the service station.
        Sent from my SM-G955U using Tapatalk
        • Kiran Otter
          • Dec 2013
          • 1100
          It could be the fan on the service station, however a 21:10 error could mean the service station motor was stalled due to blockage. I've found all sorts of things in the service station; post-it note pads, rubber bands, binder clips.. so check that there isn't something caught in it. You can move the service station by turning the white gear on the outside. If it has a fan, that could be the problem as well as Lance described. Even if you get a new service station, it won't come with a fan (usually) so you will still need to update the firmware to get around the missing fan. I haven't had to go through that in eons though so I feel it may be unlikely in your case.
          Kiran
          • theengel
            • Nov 2011
            • 1784
            Usually, when I get a service station error, I just take it out, take it apart, clean with lots of water, and put it back together.
            But yeah--get the service manual.
