Color laserjet pro MFP M477 59.F0 error
  • Ginbolero
    • Apr 2013
    • 44
    [Error Code] Color laserjet pro MFP M477 59.F0 error
    Hi. I've had two of these in 1 week, error 59.F0 (I.T.B. Alienation contact error)
    I get the same error without any toner carts in.
    I know the cp3525 had this error which normally turned out to be a sticky solenoid on the fuser drive assy. This is a completely different engine and probably too new for sticky solenoids.
    These machines are virtually throw away, but i'd like to get to the bottom of this error, 'cos I reckon we are going to get quite a few more of these with the same error.
    Anyone had any luck fixing this error?
    • 22801
    Re: Color laserjet pro MFP M477 59.F0 error
    did you run the Alienation Test? pass or fail?
    what is the page count on the ITB?
    what have you done to it so far?
    have you tried swapping ITB's?
    • Lance15
      • Jun 2015
      • 1073
      Latest CPMD recommends replacing the ITB. RM2-6454-000CN
        • 22801
        Hey Lance15,
        those are pretty pricey .. do you use rebuilds? and if so.. where from? reliability?
        • Lance15
          • Jun 2015
          • 1073
          Honestly, I've never replaced the ITB in one of these. Probably never will.
          But, on the subject of ITB replacement in general. We always use new OEM's. We don't even bother with refurbed ITBs. Not worth the hassle. We've either got a previous go-ahead and fix whatever is needed regardless of cost, or, we send pricing if they ask.
          • Zeldaman
            • Mar 2011
            • 946
            Hi there!
            This is the info from HP for this problem, published last week (i hate this boxes !!!)
            Greetings...
            • Lance15
              • Jun 2015
              • 1073
              Uhhhhhhhhhhhhhh, yeah........that'll work. *rolling eyes*
              • Ginbolero
                • Apr 2013
                • 44
                1) Can't find alienation test on this model
                2) This won't print anything and there doesn't seem to be an on screen error log but it's less than a year old and everything looks pretty new.
                3) Not much, thought I'd post on here for some pointers..
                4) ITB'S for these are not much less than a new machine, and it's a long job to change one.
                • Ginbolero
                  • Apr 2013
                  • 44
                  Hi there!
                  Greetings...
                  This isn't going to work, I can't get one page out of it. Not sure what bright spark at HP wrote that
                  I'm beginning to hate these boxes too.
                  If it's a problem with the ITB, what actually fails on them? The belts themselves look fine.
                  Thanks for your help anyway guys.
                  • Lance15
                    • Jun 2015
                    • 1073
                    Typically the fuser drive assembly. If these even have something like that. I don't think I've come across one of these yet.
                    The fuser drive assemblies I've replaced on the 3525's & 4525's seem to be okay too. Even the solenoid LOOKS okay. No sticky pad, pad doesn't look to squashed, etc. I'm wondering if the solenoid just went bad.
                    I think on this model, it must be part of the main drive? There is a developing motor on the right side, but, I don't see any gear clusters on that side of the printer that it would drive in the exploded parts view.
                    • techie0419
                      • Apr 2017
                      • 36
                      I don't know what causes it. I had one of those errors on a 452 recently, followed the manual by changing the drum motor, no go. Changing the transfer belt fixed it. Just go with it.
                      • Zeldaman
                        • Mar 2011
                        • 946
                        • ofcourse
                          • Jul 2017
                          • 6
                          Yes, this 59.F0 error is becoming a very common issue on these models as well as M452 series, recommended solution is to change the Transfer Belt Assembly. Here's an article -- 59.F0 error HP Color LaserJet M452nw M452dn M452dw M377dw M477fnw M477fdw
                          • 20 year tech
                            • May 2014
                            • 580
                            try updating the DCC firmware first it has worked for me several times those ITB units are expensive
                            HP Color LaserJet Pro M452, MFP M377, MFP M477 - 59.F0 Error (Service Action Advisory)
                            DESCRIPTION A 59.F0 error displays on the control panel and persists even after the printer is rebooted. The error indicates that the Intermediate Transfer Belt (ITB) Assembly might have experienced a hardware failure that is unrecoverable.
                            note:
                            The 59.F0 error might appear intermittently at first, but displays more frequently with continued use after rebooting. This Service Action Advisory applies only to cases in which rebooting (turning the printer off, and then on) does NOT resolve the 59.F0 error.
                            Figure : The 59.F0 onscreen error
                            The 59.F0 error triggers a related 59.0240 error that will appear in the Event Log section of a Service Page Report. The 59.0240 error code also indicates an ITB hardware failure.
                            Figure : Example of 59.0240 error code appearing in the Event Log
                            SCOPE
                            Products Product Number
                            HP Color LaserJet Pro MFP M377-M477 series CF377A/CF378A/CF379A/M5H23A
                            HP Color LaserJet Pro M452 series CF388A/CF389A/CF394A
                            Products and Serial Number Cross ReferenceThis service action advisory applies ONLY to models with serial numbers that start with VN D, JP B, or VN F:
                            Product model Serial number range
                            110V VN Dxxxxxxx
                            110V JP Bxxxxxxx
                            220V VN Fxxxxxxx
                            RESOLUTION In cases in which rebooting the printer does not resolve the issue, choose one of the following service actions:
                            Method 1: Upgrading the DCC firmware (preferred)Upgrade DCC firmware to controller number 15101. This is the preferred solution for the following models, which have a USB drive in the front:
                            • HP Color LaserJet Pro M452dw
                            • HP Color LaserJet Pro MFP M377dw
                            • HP Color LaserJet Pro MFP M477fnw
                            • HP Color LaserJet Pro MFP M477fdn
                            • HP Color LaserJet Pro MFP M477fdw
                            Follow these steps to upgrade the firmware:
                            1. From a computer, download the prn file and upgrade instructions from HPRC-INC File Transfer Service. Log in using the following credentials:
                              • Account name: dccfw
                              • Password: .Gbu1108
                            2. Follow the onscreen instructions to download the DCC upgrade instructions.pdf and DCCV1_51.prn files.
                            3. Copy the DCC V1_51.prn file to a USB drive that uses the FAT32 format.
                            4. Turn the printer on, if necessary.
                            5. Plug the USB drive into front USB port.
                              Figure : USB ports
                            6. Press the Home button on the control panel to return to the Home screen.
                              Figure : Pressing the Home button on the control panel
                            7. Select USB on the control panel.
                              Figure : The USB selection on the control panel
                            8. Select Print Documents .
                              Figure : The Print Documents selection on the control panel
                            9. Select and print the DCC V1_51.prn file.
                              Figure : The PRN file
                            10. Check to ensure that the Printing started screen displays.
                              Figure : The "Printing started" message
                            11. When asked if you want to print another file, select No .
                              Figure : Control panel prompt
                            12. Wait for the upgrade to complete.
                              note:
                              The printer will automatically reboot during the upgrade. Do not turn the printer off while the upgrade is taking place.
                            13. After the printer reboots and returns to a ready state, print a Configuration Report to ensure that "15101" is listed under Controller Number.
                              Figure : Configuration report listing 15101 as the controller number
                            Method 2: Replace the Engine Controller PCB AssemblyIf upgrading the DCC controller firmware is not an option, replace the engine controller PCB assembly.
                            Part number Part description
                            RM2-7909-0 20CN Assy-Engine Controller PCB (duplex)
                            RM2-7910-0 20CN Assy-Engine Controller PCB (simplex)
                            Method 3: Replace the Intermediate Transfer Belt AssemblyIf upgrading the DCC controller firmware is not an option, and if the engine controller PCB assembly is not available, replace the intermediate transfer belt assembly.
                            RM2-6454-000CN Intermediate transfer belt (ITB) assembly
                            SERVICE ACTION Fix on specified failure
                            Order Type Code (OTC) : 02g
                            Contact : Liu, Hai-Tao (Leo) - haitaol@hp.com
                            Originator : Liu, Hai-Tao (Leo) - haitaol@hp.com
                            Components Affected : N/A
                            Third Party Products Affected : N/A
                            Create Service : Yes
                            Create Customer : No
                            REVISION HISTORY : Rev. 1
                            Geographies Affected : Asia Pacific and Japan, Europe/Middle East/Africa, Latin America, Canada, United States
                            Action Required : true
                            Support Communication Cross Reference ID : IA06210753
                            Objective : Recommended Modification
                            Recommended Action : Fix on Specified Failure
                            Labor Hours Allowed : 0
                            Labor Minutes Allowed : 15
                            Service Delivery Type : Customer Site
                            Effective Start : 01-Dec-2018
                            Effective Expiration : 30-May-2019
                            Labor Covered : By Warranty
                            Parts Covered : By Warranty
                            Travel Covered : Not Covered
                            Originating Entity : 4600
                            Parts Strategy : Managed Program
                            Service Inventory : Return
                            Used Parts : Return
                            Hardware Platforms Affected : HP Color LaserJet Pro M452 series, HP Color LaserJet Pro MFP M377 series, HP Color LaserJet Pro MFP M477 series
                            Operating Systems Affected : Not Applicable
                            Software Affected : Not Applicable
                            • ofcourse
                              • Jul 2017
                              • 6
                              Eh, it may resolve but I think updating the DCC firmware is a "band-aid" solution -- there's an actual physical defect, a sensor in the actual ITB that is prone to malfunctioning and my guess is HP uses the firmware revision to disable that sensor. Seems kinda shady. You'll notice at the bottom of the "Service Action Advisory" that if the firmware upgrade is not possible, the recommended solution is replacing the ITB. It is an actual hardware problem but somehow the firmware overlooks / overrides.
                              note:
                              SCOPE
                              110V VN Dxxxxxxx
                              110V JP Bxxxxxxx
                              220V VN Fxxxxxxx
                                Figure : USB ports
                                note:
                              Used Parts : Return
