Hp color laserjet 4700 reset fuser and itb counter
  • Nikola Karamanov
    • Apr 2016
    • 58
    Hello, everyone! I am interested in how to reset a counter on HP Color Laserjet 4700 on fuser and transfer belt! There is information that it goes with a resistor, but I haven't tried whether it works. I would be very grateful if anyone knew and tried this method!!
  • atadikohp
    • Apr 2017
    • 46
    Re: Hp color laserjet 4700 reset fuser and itb counter
    I can do it on the ITB but not the fuser. Still looking for the method on the fuser
      • 22801
      new parts will reset it ...
      are you using USED or third party parts?
      • Nikola Karamanov
        • Apr 2016
        • 58
        HI! I use USED parts. For the ITB there is resistor which can be changed, does not look difficult! I haven't tried with the fuser unit yet. The fuser unit must have resistor too. New parts are very expensive!
          • 22801
          you will have other issues down the road if you continue with this practice.
          • AL parts
            • Jun 2019
            • 61
            4700 fuser kit.jpgIn fact, you only need to replace the resistor to achieve reset.
            www.gzanling.com
            • Nikola Karamanov
              • Apr 2016
              • 58
              In this case I have parts to recycle the fuser unit, sleeve, gears... i just need to reset the counter!
              • AL parts
                • Jun 2019
                • 61
                Yes, the refurbished fuser is also done this way.
                www.gzanling.com
                • Lasersupplies
                  • Jul 2011
                  • 221
                  A resistor under the back cover resets the fuser assembly. I have seen this fuser run a few times, eventually the sleeve or pressure roller goes but you will get another run. As for the ITB, these things never fail on this model. So robust!! i wish HP had stuck with this belt instead of the CP range they brought in, nothing but problems.
                  • Nikola Karamanov
                    • Apr 2016
                    • 58
                    Thank You very much! Do you know the resistance of the resistor and whether the watt matters?
                    • Nikola Karamanov
                      • Apr 2016
                      • 58
                      It works!!! For the fuser and transfer belt, resistor 33 ohm!
