HP P3015 tray 2
  • nathicana
    • Aug 2008
    • 327
    HP P3015 tray 2
    This HP P3015 jams every time from tray 2 the standard drawer. Rollers don't turn at all. Paper feeds from tray 1.
    Jam is 13.01.00
    I can hear a thump when testing pickup solenoid for tray 2. Previous tech replaced solenoid and pickup roller.
    I'm interested in troubleshooting tips
  • buf7579
    • 12
    Re: HP P3015 tray 2
    Jam is 13.01.00
    Tray 2 pickup assembly is likely shot. RM1-6268 is the part number.
    Instructions for replacing:
    • nathicana
      • Aug 2008
      • 327
      Re: HP P3015 tray 2
      https://www.laserpros.com/img/TechTi...eplacement.pdf
      Thanks. I took the ECU board out so I could test the Tray 2 pickup assembly manually. If I turn the drive system and actuate the pickup solenoid the unit feeds paper so I think it is okay.
      Maybe the solenoid isn't pulling all the way even though I can hear a sound. It is brand new though.
      This printer is displaying a "Used toner" message. Could the message be preventing the control board from turning on the tray 2 solenoid during printing?
      I need to be able to watch the solenoid during a print cycle but I don't see a way.
      • nathicana
        • Aug 2008
        • 327
        Re: HP P3015 tray 2
        The printer is now working, here's what happened:
        I had the printer disassembled in order to inspect the feed system for drawer 2.
        After finding no apparent mechanical problems I reassembled the printer and turned it on.
        During initialization the printer displayed a 49.4C02 code and restarted on its own.
        It took a fair amount of time to come to ready then everything started working again.
        There were no pending print jobs and I had done firmware before taking the printer apart.
        The original symptom was no rotation of drawer 2 pickup rollers with jam 13.01.00
