HP ColorLaserJet MFP M577
  • Nikola Karamanov
    • Apr 2016
    • 58
    Hi everyone! I need to replace HDD to HP ColorLaserJet MFP M577, but when i try to install last date firmware and machine trying to loading i getting error 98.00.02. I was trying with different HDD, formater board and firmware. I was try to unlock/erase and format the HDD but its the same error! 85202330_950967528634161_1451560845669564416_n.jpg
    • 22801
    Re: HP ColorLaserJet MFP M577
    Originally posted by Nikola Karamanov
    Hi everyone! I need to replace HDD to HP ColorLaserJet MFP M577, but when i try to install last date firmware and machine trying to loading i getting error 98.00.02. I was trying with different HDD, formater board and firmware. I was try to unlock/erase and format the HDD but its the same error! [ATTACH=CONFIG]44877[/ATTACH]
    sounds like you didn't follow the service manual procedure
    • Nikola Karamanov
      • Apr 2016
      • 58
      I was follow everything! still the same!
      • Lance15
        • Jun 2015
        • 1073
        98.00.02 Corrupt data in the solutions volume
        Data corruption has occurred in the solutions volume.
        Recommended action:
        Turn the product off, and then on.
        Use the Format Disk item in the Preboot menu.
        Reload the firmware.
        Did you order a new/unused HDD? Did it come with instructions on installing it?
        • Nikola Karamanov
          • Apr 2016
          • 58
          I was trying to Format disk in the preboot menu but didn't help! The HDD's its not new/unused, i will try with new one. If the size is under 320 GB is that a problem?
            • 22801
            what model/size did you pull out?
            hp is very picky most time on that
            are you SURE you have the manual?
            • Nikola Karamanov
              • Apr 2016
              • 58
              The size was 320 GB, replacing guide hdd is from here HP LaserJet Enterprise MFP M577, HP LaserJet Managed MFP E52545, E57540 - Removal and replacement: Hard-disk drive (HDD) | HP(R) Customer Support , the manual is from here https://yadi.sk/d/JPQ_NMlO3MHAs2
              • Lance15
                • Jun 2015
                • 1073
                When it comes to HDDs, I NEVER order refurbished/used ones.
                5851-6712 - 320GB Encrypted HDD kit
                It should come with instructions on installing it. I remember installing a few of these and after it's physically installed into the machine, you are placed into the Preboot menu and you have to unlock (or something) the drive. I don't remember exactly, but, I vaguely remember something like that before the drive will work.
                • Nikola Karamanov
                  • Apr 2016
                  • 58
                  Is it matter the brand of HDD, if I use different brand from this kit?
                  • Lance15
                    • Jun 2015
                    • 1073
                    If you ordered the part number I provided, it will come in a box with instructions on how to install it. Whatever HP sends will work.
                    • Nikola Karamanov
                      • Apr 2016
                      • 58
                      With HHD kit from HP works perfect! Thanks!
