HP LJ Pro M476
  • aAandy
    • Apr 2012
    • 367
    [Jamming] HP LJ Pro M476
    ITB stops momentarily when paper reaches transfer roller, resulting in a z-fold jam - as a temp measure i cut down the transfer roller springs to reduce pressure
    would like to return with a permanent fix - anyone seen this before?
    thanks in advance
  • aAandy
    • Apr 2012
    • 367
    Re: HP LJ Pro M476
    bump
    anyone? anything?
    • GIUBOSS
      • 1382
      Re: HP LJ Pro M476
      have you checked all the flag sensors if they return correctly? how many prints does it have, transfer condition and fusers?
      • aAandy
        • Apr 2012
        • 367
        Re: HP LJ Pro M476
        110k, paper sensor flags all operate normally, transfer & fuser look fine - ITB stops just for a moment when paper reaches registration, then jams with a 1 inch Z fold at the top - reducing the transfer roller pressure by cutting down the springs got it to work but this is only a temporary solution
        during warm-up with the back door cheated i could not stop the ITB with my finger
        • GIUBOSS
          • 1382
          Re: HP LJ Pro M476
          condition of the paper pick-up rollers?
          • aAandy
            • Apr 2012
            • 367
            Re: HP LJ Pro M476
            new - curious to know what you think a feed roller may have to do with the ITB stopping when paper reaches registration?
            • GIUBOSS
              • 1382
              Re: HP LJ Pro M476
              usually I do not neglect any details for jamming problems, a delay or advance on the paper detachment could compromise the time on the way to the register. The register magnetic clutch to be checked
              • aAandy
                • Apr 2012
                • 367
                Re: HP LJ Pro M476
                after 34 years of printer repairs, neither do i as these are the first things any tech checks before consulting other techs
                thank you kindly for your responses, but i am looking for responses from people who have seen this specific problem before and have successfully applied a solution
                i agree the ITB drive clutch is the likely culprit as reducing the transfer roller pressure remedied the problem and got the machine working, however i couldn't stop the ITB during warm-up with my finger
                • GIUBOSS
                  • 1382
                  Re: HP LJ Pro M476
                  I would try to invert the two main motors if you have time ..
                  • tech28
                    • Jun 2013
                    • 434
                    Re: HP LJ Pro M476
                    Paper size? By pass doing same thing? Have seen that problem before a few moons ago, sorry have to see if I have a solution in my files. Ill get back, not much work coming in.
                    • spree
                      • Jun 2012
                      • 211
                      Re: HP LJ Pro M476
                      Hello. Problem with HP color LJ Pro M476: paper jam in tray 3. But the printer has only tray 1 (manual) and tray 2. Error log (13.000 - paper jam). Sometimes continue printing 30 pages and after that "paper jam in tray 3.". Than turn OFF/ON and immediately "paper jam in tray 3". Try to replace pick-up in tray 2 :-), try to upgrade FW, try to print from tray 1, from tray 2, try to make copies (without sending jobs from PC) and still the same... Any ideas? Formater (maybe)?
