HP LaserJet Enterprise M608n Grinding noise
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    The noise is intermittent and when it happens it is usually at the start of the print cycle, Sounds like
    it is coming from the top rear right side of the printer. I put some gear grease on the fuser and the paper eject gears
    on the right side of machine although ALL the gears look pristine.Fuser also looks good and clean.80,000 prints on machine,
    It would be easier if happens more frequently but fairly loud when it happens. Has anyone had this type of problem with this
    machine? Only have seen a few but I thought I had same problem with another machine in this series but customer really didnt care about the noise,I was relieved
    at that time when they told me that().
    Any insight and help greatly not taken for granted.
    THANK YOU
    ANDY
    • 22801
    Re: HP LaserJet Enterprise M608n Grinding noise
    Originally posted by cucuklotz
    Hi
    on the right side of machine although ALL the gears look pristine. Fuser also looks good and clean.80,000 prints on machine,
    THANK YOU
    ANDY
    did you lube the bushings? USE Tri-Flo oil on them.
    you could always cheat the back door interlock and see if any gears/shafts are jumping
    • JR2ALTA
      • Feb 2010
      • 2027
      I would replace the fuser. These have a retraction mechanism for envelopes that may be slipping.
      • theengel
        • Nov 2011
        • 1784
        having the same problem on a m608. ive replaced the fuser. did you ever figure it out?
