hp e 77822 error code 63.00.08
  • bejoyjohn
    • Nov 2008
    • 45
    [Error Code] hp e 77822 error code 63.00.08
    hi guys I have a hp machine e77822 mfp and initially the problem was 63.00.3f and when i tried to remove it by rotating the toner and drum but when i restarted the machine this error came. what is this code for and how to remove it ...no idea. please give me some ideas.
  • Michael
    • 158
    Re: hp e 77822 error code 63.00.08
    Hello,
    maybe this link help you
    The printer may see a 63.00.3B, 3D, 3F, or 41 Toner Concentration Error when Developing Unit is depleted.
    ftp://ftp.hp.com/pub/networking/soft..._25_30_fs4.pdf
    My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
    You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
    • bejoyjohn
      • Nov 2008
      • 45
      thank you . but my error code is 63.00.08
      • Michael
        • 158
        you wrote: and initially the problem was 63.00.3f
        did you make the firmware update as descriebed in pdf?
        • bejoyjohn
          • Nov 2008
          • 45
          this code is for Cyan developer unit problem with toner supply or calibration
          • Wow_copier
            • Feb 2020
            • 6
            Hi, OK did you find out how to clear the code 63.00.08 on HP Managed Flow? I also started out with the same code 63.00.3F cyan toner BS. So swap out the toner.. nothing, so then I refill the developer cyan, then I looked in service mode to stir the developer or manually add toner but I only find main engine turn & drum engine turn so I did all them trying to stir the developer but then I reboot the machine & get the 63.00.08 unknown code?? HP ruined these machines, I never had any trouble working on them when they were branded Samsung but HP is always trying to bend you over & shove a cartridge up your back side!! Any solution clear code 63.00.08?? _Thanks
