HP Designjet 1050C Plus
  • CP-1015
    • Nov 2020
    • 298
    Hi,
    please help with printer issue under Win 10 Pro 64bit
    In printer properties: see picture HP1050C.pgn, please.
    In printer settings: see picture HP1050C2.pgn, please.
    Printing is not possible. No new driver from HP.
    I don't want to buy an driver for 175 Dollar.
  • Kiran Otter
    • Dec 2013
    • 1100
    Re: HP Designjet 1050C Plus
    Use the Windows Vista x64 driver from HP. It works.
    Kiran
    • Michael
      • 158
      maybe it should be a microsoft update which makes the trouble:
      Windows Update 06-2020 Druckprobleme - Designjet Plottershop - HP gebrauchte Plotter - Ersatzteile - Windows 10 Treiber Designjet 500
      Windows 10: Neueste Updates machen Drucker unbrauchbar
      i have had this with epson printers also, after update from microsoft , the printer not working. seems something with the printerqueu.
      My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
      You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
      • CP-1015
        • Nov 2020
        • 298
        Originally posted by Kiran Otter
        Thanks, but I've alredy tested without success.
        • CP-1015
          • Nov 2020
          • 298
          Yes, it disable printerque.
          Thanks, but KB4560960und KB4557957 is'nt installed but the KB4568831,
          • Kiran Otter
            • Dec 2013
            • 1100
            Michael is correct, there was an update from MS that caused various printers to stop working. The easiest fix for that is to make sure you have ALL updates to Windows 10 installed, including new builds.
            Kiran
            • Michael
              • 158
              Kiran
              uninstalled this updates helped me in this case...
              but block this updates and wait until microsoft install new updates automatically..
              • CP-1015
                • Nov 2020
                • 298
                Kiran
                ALL updates are installed. But I'll test it again.
                • Kiran Otter
                  • Dec 2013
                  • 1100
                  If nothing else, have you tried clearing out the drivers and starting over? If you go to Devices and Printers, and select any printer, there will be an option at the top of the window that has Print Server Properties, and from there you can manually remove drivers. I would remove any HP drivers you've installed, reboot, and reinstall using the Vista 64 driver I linked to.
                  Btw, if it says the driver can't be removed because it's in use, just stop and restart the print spooler service and try again.
                  Kiran
                  • Michael
                    • 158
                    i would delete first all this microsoftupdates which are signed for making trouble, not mess up the computer with drivers... i do this for the epson problem and it works after a computer restart...
                    and another advice is to use a testing computer for trying printer drivers and make before an image with acronis , so you have alltime a clean machine for testing drivers...
                    • CP-1015
                      • Nov 2020
                      • 298
                      Now I tried it again. "KB4568831 is not for your computer"
                      Winver 20H2, but with 2004 was the same.
                      • Michael
                        • 158
                        did you uninstall the KB4568831 ?
                        i would try this...
                        • CP-1015
                          • Nov 2020
                          • 298
                          I think for fixing I have to install this. But it is not on my computer and I'm not able to install.
                          • Michael
                            • 158
                            i would do this:
                            1. take a spare computer with a ssd ! or your an put in new ssd
                            2. install fresh windwos 10 after that make an IMAGE !!!! with acronis
                            3. then test if this works after install drivers..
                            using a machine which is just messed up with drivers and trial and error updates is not good start position...
                            good luck ..
