Hi everyone i have Hp laserjet mfp 426 displaying scanner error 13 there is no paper jam have tried to reset to factory setting still its giving me some error code
scanner error 13
My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there. -
Re: scanner error 13
Found in Troubleshooting Guide. Viewable on support.hp.com30.0013 Scanner Error 13
The scanner motor is unable to find the home position. This error typically occurs during the startup sequence.
Turn the printer off, and on again, and then try the job again.
If the problem persists, replace the scanner motor. Contact HP support: www.hp.com/go/support
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
same as Microsoft windows: switch on and off the computer and try again:-)My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.Comment
XXX error with xxx
1 ) remove the surge protector and turn on the printer
2 ) Replace xxx
3 ) Replace the productComment
