A Complete Guide Reset HP Printer Factory Settings and Password Reset
  • jamessmith09
    • Jul 2021
    • 2
    According to HP, the default settings of your printer are not reset when you restore them.Read full blog to reset hp printer
    These steps will restore your HP printer's factory default settings.
    1. Turn off the printer. After 30 seconds, disconnect the power cable and then reconnect.
    2. Press and hold the Resume button while the printer is turned on. The Attention light turns on.
    3. Release the Resume button. While the printer restores factory defaults, the Attention, and Ready lights cycle.
    HP Printer "Out Of Paper" Reset
    Except for the erroneous message that the paper is empty, we love our HP printer.
    The paper tray has plenty of sheets...so why doesn't it see them?
    This problem can be solved by simply unplugging your HP printer.
    It is very simple:
    • Once the printer is turned on, remove the power cable at the printer's back.
    • Unplug the power cord from the wall outlet
    • Wait 15 seconds
    • Connect the power cable to the printer's back
    • Connect the printer to the wall outlet
    • Turn the printer off
    • Run a test print
    These steps will reset the "out of papers" message on your HP printer.
    How to reset the password on your HP printer
    There are several ways to reset your HP printer's password. It is a good idea for your printer to be reset on a regular basis, especially if the printer is being used by a group of people such as in an office setting or classroom setting.
    HP Printer Password Reset: Method 1
    • Once your printer is turned on, hold down the Wi-Fi and cancel buttons simultaneously. This will activate setup mode for your HP printer.
    • Download the HP Smart app onto your Android device or iPhone to complete the password change procedure.
    • Choose "Printer Setup" from the HP Smart App. "
    • Scroll down and select "Advance Settings".
    • Choose "Settings & Security"
    • Select "Password Settings" in the drop-down menu.
    • The prompt will ask you to create a new password for the HP printer.
    Also read: What is hp solution center
    HP Printer Password Reset: Method 2
    This method can be used without the need to download the HP Smart App.
    • Your HP Printer's Home button is pressed
    • Choose "Settings".
    • Select "Setup"
    • Select "Reset Password"
    HP Printer Password Reset: Method 3
    You can also reset your HP printer password from Windows using the Windows operating system.
    • Open the Control Panel
    • Choose "Devices & Printers"
    • Right-click the wireless HP icon
    • Click on "Properties".
    • Click "Reset Password"
    • Save changes by entering a new password
    Reach Out To Hp Printer Customer Service to Fix Error
    If you are facing error with your hp printer then just dial our hp printer customer service number 817 442 6637 to fix the error.
