E67660 error 49.38.07 no ethernet
  • copydocinc
    • Mar 2015
    • 263
    Getting code 49.38.07 without printer cable plugged it also got 98.00.00
    I have flashed newest firmware. I have uninstalled and reinstalled drivers,
    but with network cable not plugged in, it still will give the 49.38.07 code and
    then work for a couple days, then come up again. we clear out the print jobs
    on all computers if any, reset with cable unplugged. try copying and it works,
    but has come back again before plugging in network cable. tried flashing
    firmware again, it clears. Comes back. tried partial clean and format disk a few times.
    Also did the erase and unlock thing. Reflashed firmware. Can't seem to get away from
    this error code. Sometimes it comes up as 49.38.0C
    Do I need to replace harddrive or formatter?
    Help, thanks
  • DRichard
    • May 2008
    • 482
    Re: E67660 error 49.38.07 no ethernet
    Help, thanks
    See my post of a few weeks ago. It might help?HP PageWide E77650 Displays 49.38.07
    Good luck.
    "Enjoy every sandwich."
    -- Warren Zevon
