HP M603 - error 50.93.11
  • SUICIDE
    • Apr 2022
    • 6
    [Error Code] HP M603 - error 50.93.11
    Hello. i`m first time on this forum .
    i have looking on google for solution to fix problem with my HP Laserjet M603
    The fuser was deostryed and i have order the new one.
    after replace the fuser i run my printer.
    When i try to print raport or something else the printer show me error 50.93.11 - fuser error
    there is no information about the error on manual, on official hp site to.
    Maybe someone in here have the same problem.
  • Drivee
    • Nov 2020
    • 322
    Re: HP M603 - error 50.93.11
    Maybe you order 110V and you need 220V or vice versa. That error mean that fuser temperature is low. You have last firmware?
    • SUICIDE
      • Apr 2022
      • 6
      my old destroyed fuser number of version is rm-1 8396 200V i have order with the same numbers. All parameters are the same. Thats weird.
      i have made couple tests , trying to print then power off printer, power on again with another print. Then i have update to new firmware and the same issue.
      • Drivee
        • Nov 2020
        • 322
        Can you measure temperature of fuser? It is worm. Maybe is just a defective fuser. What was wrong with old fuser?
        I would check temperature of fuser.
        • SUICIDE
          • Apr 2022
          • 6
          The rollers were damaged.
          i thought about to replace only the rollers from the new fuser to the old.
          But is hard to dismantle cables . They are very tense.
          • Drivee
            • Nov 2020
            • 322
            I think to use old fuser just to see does printer work, if work, then return fuser which you bay. Maybe thermistor is bad or similar.
            • Lance15
              • Jun 2015
              • 1073
              Did you order a new fuser, or a rebuilt fuser?
              • SUICIDE
                • Apr 2022
                • 6
                Like i said before. It was a new fuser.
                The old one dont have the error code like that one.
                But the old fuser have rollers damaged.
                • SUICIDE
                  • Apr 2022
                  • 6
                  i have check that new fuser in the other working printer. The result was the same.
                  i send it back and wait for the new one. i hope it will work. I give u information.
                  • SUICIDE
                    • Apr 2022
                    • 6
                    service/shop didn`t belive us that the ordered new fuses have problem.
                    We have send our printer them .
                    The result was the new fuser is bad. They have replace a new one and printer works good.
                    Thank you anyway for your help.
                    • LKJUJYHSDR2342
                      • Sep 2021
                      • 5
                      Do you have an update? How is it going?
                      • Crowfeather
                        Printer firmware is !&$!
                        • Mar 2021
                        • 127
                        Its a rebadged canon, buy a canon they work better.
                        P.S -> Could be a issue with the fuser board. Also did error exist before you fit the fuser? (nvm read on yeh bad fuser, old fuser no error)
