HP M477fnw image quality issues
  • Kiran Otter
    • Dec 2013
    • 1100
    A customer of mine asked if I knew how to fix a HP Color Laserjet M477fnw. I told them I didn't but I would look into what it might take to fix it. It looks to me like something contaminated the transfer belt, but I really know nothing about laserjet printers. It's made +70K prints. Is this printer worth repairing? Attached is an example of what it's doing. Anytime they print something with a lot of color, that area ends up repeatedly showing part of a print in that area. It looks like it's always in the same place though, from the examples I saw. I've attached an example. They are using HP supplies, but at one time had tried 3rd party cartridges. After they leaked toner they went back to the HPs. I don't know how old the printer is.
    Thanks,
    Kiran
  • GIUBOSS
    • 1382
    Re: HP M477fnw image quality issues
    Thanks,
    Kiran
    I think it's more of a fuser problem, did you take a look at the wear condition of the fuser? Try locking the sheet before it completely exits the fuser to be sure.
      • 22917
      It looks like fuser to me too. The measurement I took from your scan looks like 2.23" or 56.6mm. That's a bit small for a heat roller, but maybe correct for the pressure roller. It should be obvious from the examination of the fuser rollers if the problem is there. The 56.6mm defect interval indicates a roller of 18mm diameter.
      This is not one of those HP fusers that is particularly easy to get to. The book shows all the covers coming off to get it out.
      • JR2ALTA
        • Feb 2010
        • 2027
        This is definitely fuser. I speak from experience because on this stupid model, you can't check the condition of the rollers without removing it.
        Removal is tricky but YouTube has everything you need. The bigger problem is the $$. These are considered throw away printers by many because of parts and labor expense.
        • tech28
          • Jun 2013
          • 434
          Fuser, if its simplex. looking about 250.00 plus installation(20-30minutes) If its duplex 350 and up for fuser. Didn't see d in your definition of model so it's simplex.
          • Kiran Otter
            • Dec 2013
            • 1100
            Thanks for the input from everyone. Sounds like it's not worth it to repair it, at least in this situation. Plus I probably wouldn't attempt it, even with the service manual. Laserjets aren't my gig.
            Kiran
            • techie0419
              • Apr 2017
              • 36
