Just replaced all printheads a week ago, now I get that one printhead is bad! DJ500
  • RHOPKINS
    • Jun 2022
    • 64
    Well I got rid of my 29:10 error by replacing the ISS unit. During the test it now says one of my printheads is bad (Black). I just replaced all the heads when it started the banding mess. Is there anyway to get by this error? I really don't think this printhead is bad, as it does not have 15 minutes usage on it.
    Richard
  • RHOPKINS
    • Jun 2022
    • 64
    Re: Just replaced all printheads a week ago, now I get that one printhead is bad! DJ
    Some additional information I am getting a code 34 for the printhead.
    • Kiran Otter
      • Dec 2013
      • 1100
      I would just replace it. Always rule out the consumable first.
      Also make sure the firmware is up to date. There were issues with the #10 printheads and the dates.
      Driver - HP DesignJet 500 Printer series | HP(R) Customer Support
      Kiran
      • RHOPKINS
        • Jun 2022
        • 64
        Kiran
        Yes I updated the firmware before I started all the changeouts. Have a new printhead coming so will wait and see. Thanks Kiran for your input.
        Richard
        • Kiran Otter
          • Dec 2013
          • 1100
          I would order all the inks and printheads you expect to ever need. HP is discontinuing them in November. The black ink cartridge was discontinued last November.
          Kiran
          • RHOPKINS
            • Jun 2022
            • 64
            Kiran
            Boy that is great news, I guess we'll have to wait and see if anyone rebuilds them. I have several of the color heads but only had one black. Wish I knew what the error 0034 stood for. Kiran I tried to upgrade to the link you sent me but it seemed like it did it to fast and fell through the routine. My guess you have to have all the printheads working before it will let you upgrade. Is that the case?
            RIchard
            • RHOPKINS
              • Jun 2022
              • 64
              Well, I just replaced the bad printhead. It still has the X showing for the black printhead. Where else could be the problem?
              • Kiran Otter
                • Dec 2013
                • 1100
                I thought you updated the firmware already? Yes, I would presume the printer must be ready to accept the firmware update.
                If the printer rejects multiple printheads, then I would suspect there is something wrong with the carriage or the contacts the printhead mates to. You could have another bad printhead that is making the black not work. Try reseating them all and make sure the contacts are clean.
                If the firmware isn't on 5.01 then you need to resolve that first. I think you can view the firmware version through the front panel... somewhere.
                Kiran
                PS - Put the black in by itself and see if you get the X or not. If not, then it's likely another printhead causing a problem.
                • RHOPKINS
                  • Jun 2022
                  • 64
                  Kiran
                  Ok I removed the other printheads and it still shows a x on the black head. How do I get to the cables that plug into the printhead carriage? Yes I did the firmware upgrade before I started this nightmare.
                  richard
                  • RHOPKINS
                    • Jun 2022
                    • 64
                    Kiran;
                    I can't check the firmware won't let me get information. Removed all the printheads except the black and I still get the X on it. How do I go about getting to the cables that go to the carriage?
                    • Kiran Otter
                      • Dec 2013
                      • 1100
                      I doubt it's the trailing cable. If that was an issue you'd get 11:11 errors. It may be the carriage, or the EMOD. Removal of the carriage and trailing cable are covered in the service manual.
                      If you replace the trailing cable, be sure to re-use the plastic stiffener from the old cable, if one exists.
                      Kiran
                      • Kiran Otter
                        • Dec 2013
                        • 1100
                        LPS also has several videos on repairing the 500/800.
                        Designjet 500, 800 Video Tutorials – Designjet Store
                        Kiran
                        • RHOPKINS
                          • Jun 2022
                          • 64
                          I found a carriage board on Ebay, that will be easier to change rather than replacing the complete carriage assembly. I have a spare electronic module assy but I suspect something has gone wrong with that carriage board. I also ordered another printhead tonight. I don't think it is that but you never know.
                          Richard
                          • RHOPKINS
                            • Jun 2022
                            • 64
                            Kiran;
                            I have removed the board from the carriage unit. While removing the ink supply tube I noticed there is still air in the tube. I used the LPS tool to remove what I thought was all the air, but I evidently have more. Do I need to pull some additional ink until the tube is solid ink? I have no idea as to how so much air got in the tubes. Unless when I replaced the ISS unit air entered the lines.
                            richard
                            • Kiran Otter
                              • Dec 2013
                              • 1100
                              I usually pull about 5ml of ink out when priming the tubes.
                              Kiran
