HP LJ Pro 300 does not produce a print, copy or report consistently.
  • RudyNYC
    • Mar 2010
    • 13
    HP LJ Pro 300 Color MFP - M375nw
    Powers up, goes thru it's self check procedure and comes to ready. I ask for a report and it might produce it or it cycles as if it did and goes back to ready. The same happens if I make a copy or send a print job. I cycle the power and the same happens. Any ideas?
    TIA.
  • GIUBOSS
    • 1382
    Re: HP LJ Pro 300 does not produce a print, copy or report consistently.
    TIA.
    Check if the toners are original or end of life, you have looked in the status monitor or in diagnostics in the printer doctor
