HP iPF710, Error code e161-403e
  • Hansoon
    • Sep 2007
    • 3347
    NOT HP, but Canon. Cannot edit the title anymore.
    Canon iPF710, Error code e161-403e
    Regarding plotters, I'm a total noob. Any help or suggestions, please?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
    • 22916
    Re: HP iPF710, Error code e161-403e
    iPF-610, 650, 670, 700, 710, 750, 760, 765, 780, 785
    "E161-403E" message. E161-403E: abnormally high printhead temperature, iPF-610.
    Printhead overheat failure. Remove the printhead while in service mode. Being in service mode temporarily clears the error condition, allowing access to the maintenance menu. If the maintenance cartridge MC-07 (1320B008AA) is at less than 40% it may fill before the process is complete, or any of the ink cartridges below 25% they may deplete before the process is complete.
    Remove printhead: unload paper, release handle forward > enter service mode: hold Info & Paper Type (picture of paper roll) powering ON until "S" appears in upper right corner > Menu > Maintenance > Replace Printhead > remove printhead > close up carriage > unplug plotter to power Off > power On > when prompted, install new printhead PF-03 (2251B003AC) > close up carriage > plotter fills the printhead with ink and asks for paper to be loaded > load roll paper > performs a head alignment.
    • Hansoon
      • Sep 2007
      • 3347
      Thanks Cat, I realized just now, that you once already gave very good instructions for this machine type. It's not the same customer, but the same machine type.
      Boy, I'm really getting old or is it just the red wine I'm drinking too often........?
      Hans
        • 22916
        That's alright, I didn't remember giving that advice. =^..^=
