HP DesignJet 1050c Color problem
  • Laka
    • Nov 2015
    • 36
    What is the problem...!
    We have av "old" 1050c that have working perfect for the last 10 years (!) and now,
    on testprint, it's only b/w on the head test but color on next part of the test page
    and when a send file to the printer it's also b/w that prints...!
    IMG_3497_s.jpg.
    Left the current one, and right the old one that's ok..!??
    Have tried to read service manual, ... could it be Drop detector ...?
    All heads ok!
    /Lars
  • Kiran Otter
    • Dec 2013
    • 1100
    Re: HP DesignJet 1050c Color problem
    I've never seen that before. When you run the test print, did you have 'color' selected on the front panel? That's about the only time when that button does anything; when printing internal prints. I don't know if it would cause that effect though.
    For it to be happening when you send a print is even stranger. What are you printing from? And what driver? Did anything change?
    It's not the drop detector.
    Kiran
      • 22920
      Just out of curiosity, how did you decide that the heads are OK? =^..^=
      • Kiran Otter
        • Dec 2013
        • 1100
        Part 3 (the color bars) of the print come out correctly, so I'd agree the heads are OK. Just my two cents!
        Kiran
        • D Hook
          • Mar 2018
          • 205
          Kiran
          That's an internal print in the Image Quality menu. I had the same problem a few years ago. I honestly don't recall exactly what it was but I'll take a look today at my 1055CM and see if I can recreate the problem. I do know it's just a menu button push problem, not an ink supply or mechanical issue.
          • Laka
            • Nov 2015
            • 36
            Thanks for the reply!
            This problem occurred after I used loose sheets for a job and after that the problem occurred!
            Tried changing a head (C) and it's still the same problem!
            Must be an internal problem in the printer (!?) because I do an internal print in the printer test menu ..?
            Regards
            Lars
            • Laka
              • Nov 2015
              • 36
              Hi!
              Have you had time to check what was possibly wrong with your printer?
              Regards
              Lars
              • D Hook
                • Mar 2018
                • 205
                Kiran nailed it. Checked it just now (sorry for the delay) and on the front panel, to the left of the display, you have a button that says "Color"/Grayscale". Be sure this is set to "Color". I just now set mine to "Grayscale" and got the same result you posted a picture of. When this happened to me awhile back I completely overlooked that button. I was doing some work on the printer and must've inadvertently set it to "Grayscale". Soon as I switched it to "Color" it started to print the Quality Image in color again.
                Hope that works for you. Thanks to Kiran for posting up the suggestion earlier.
                • Kiran Otter
                  • Dec 2013
                  • 1100
                  Heh, in all my years, I never knew that set to greyscale would affect that test print. You learn something new every day.
                  But why would it affect his prints from a PC? The settings in the driver always override the front panel settings. Unless he's using something out of the ordinary, like a generic PS driver (though he said it's a 1050C, not a 1055CM) or maybe Linux and the driver doesn't tell the PC color/greyscale.
                  Kiran
                  • Laka
                    • Nov 2015
                    • 36
                    Hi!
                    Thanks for your help...!
                    Yes, this was the problem!
                    I've worked with large format printers for almost 20 years and have never had a problem that I couldn't solve - until now...
                    A bit embarrassing that there is a button on the panel that was set incorrectly!
                    A small excuse could be that I don't use it much today except for cad drawings ..!
                    Tanks!
                    /Regards
                    Lars
                    • D Hook
                      • Mar 2018
                      • 205
                      Glad you got it going again.
                      Also, a shout out to PBrooks259. When it happened to me, he was the one who suggested checking that button and sure enough, solved it for me.
                      Sometimes, Occam's Razor holds true, even in printer problems.
