best hp monochrome laser printer
  • cleardata
    • Jul 2011
    • 137
    what's the best hp monochrome laser printer that is durable whether it's slow or fast speed printer? thank you.
  • subaro
    • Oct 2010
    • 1273
    Re: best hp monochrome laser printer
    Hp lj4050 is a reliable machine, plus its warm up time is fast. wonder why there are no reply to this thread as it is a valid question to all hp techs there.
    • Eric1968
      • 2459
      It depends on what you want with a machine. If you want to print 2000 pages a day, an old 6P machine is not the best choice, allthough this printer is a good machine. So without some more detailed info you can't answer this question.
        • 22916
        A responsible salesperson would gather a little information first:
        What monthly volume?
        B&W only or Color too?
        How many paper sizes/trays?
        What media types do you plan to print on?
        What area would you like to put the equipment (A" x B", desktop versus console)?
        Any additional functions desired? (Scanning, Copying, etc...)
        Connection type? (TCP/IP, USB)
        PC Operating System?
        I know there are a few responsible salespeople ... somewhere.
        You want a recommendation based on ... what? =^..^=
        • Chameleon
          • Nov 2011
          • 200
          If your looking for info on the printers available at the box store I can't help you there.
          If you just want a basic low end printer I'd look for a lj4050/4000 or lj4100. Very reliable. I'd avoid lj3005 they seem to have problems with the formatter PCB. The lj4300/4350/4200/4300 are very similar to a 4100 but faster. They aren't bad but seem to go through the fuser drive gears (swing plate) more often.
          If your looking for a mid-higher end I'd look for a 5si/8000, those were just tanks. 9000/9050 have replaced them and hold up just as good.
          Really, aside from the 3005 most hp are very reliable. Dell and Lexmark make a very good MFPrinter as well. I have worked on many HP, Lexmark and Dell printers and have a lj4100 at home.
          The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            The old laser jet 4, 4+, and 5 are all solid as a rock. I still fix them for people who will not give them up.
            • cleardata
              • Jul 2011
              • 137
              thank you for your replies. what about hp 4345mfp? is it durable? any issues about this model?
              • Tec1
                • Dec 2011
                • 48
                I agree with 4000/4050/4100 older but great machines
                4250/4300 series good but yes fuser and swing plate prob and some electronics
                4345MFP same as 4250/4300 just can copy also uses same swing plate assemby
                Last edited by Tec1; 01-12-2012, 04:52 AM. Reason: typed 4350mfp instead of 4345mfp
                • ucinn
                  • Jun 2009
                  • 383
                  I have about 50 of these in my area.. Mostly a very good machine..easy to work on.. swing plates replaced so far is only 1...not bad... it was on one with over 500,000 on it. The biggest problems I've had with these is the engine power supplies, have had to replace 5 of them, but they were all in the first year and under warranty. A couple hard drives and formatters, but mostly just maintenance kits. So overall, I would say they are a very decent machine.
                  • daprex
                    • Sep 2009
                    • 54
                    i would also go with the 4250 or 4300, the swingplate i easily replaced and when you have the new type with the wheel beside the gear they dont wear as much.
                    • chand
                      • Oct 2007
                      • 12
                      HP P3005dtn
                      • ucinn
                        • Jun 2009
                        • 383
                        Originally posted by chand
                        HP P3005dtn
                        please tell me this post was a joke...these are formatter nightmares.
                        • kingpd@businessprints.net
                          • 919
                          Good posts. I started a post asking about the best printer not necessarily hp specific.
