HP 5500/1f50007 Hard Disk Failure.
  • cucuklotz
    • Mar 2007
    • 611
    Customer called with multi layered series of codes that finally resulted in
    Error code 1f50007 Hard Disk Failure.Any ideas as to cause.Im thinking Main control board,but afraid to order without any other input.
    Thanks Andy
  • JustManuals
    • Jan 2006
    • 9865
    Re: HP 5500/1f50007 Hard Disk Failure.
    Paul@justmanuals.com
    • MFPs R Now PCs
      MFP Tech & I.T. Manager
      • Jul 2011
      • 156
      Try this link:
      HP Communities - 5500 ps Boot Failed error: 1f50007 Hard Disk Failu... - Enterprise Business Community
      In particular this post:
      I eventually resolved this problem back in Aug 06. Since there wasn't any available help I went with my hunch that the power supply had partially failed casuing the controller failure. When the power supply was installed the problem remained so I ordered the main controller board which then solved the problem so I now have a spare power supply but haven't put it back in the printer. Hope this helps.
      and this post:
      Steps to resolve "Error: 1f50007 hard disk failure"
      1 - Connect HDD to computer and test it with the western digital test tool (thats the brand HP used for DJ 5000 and 5500), if test fails then replace HDD, if it passes then more lickly you have a bad PWS or Main PCA
      2 - Check for wire harness between Main PCA to HDD and PWS to HDD, reseat connections if no wire harness found.
      3- If problem continues, check that the Green and Orange LED's on the Main PCA are ON. If they are not ON, probably the PWS or its connections are defective. If the two LED's are ON and the error continues, replace the Main PCA.
      Good Luck!
      It does not matter how slowly you go as long as you do not stop. –Confucius
      • cucuklotz
        • Mar 2007
        • 611
        HI,
        Thanks for help with problem,will let know how it all turns out.
        ANDY
