Hello,
My problem: I have code that opens a 79:04 screen. Must update the firmware but when updating the web window should open to select the firmware is in error.
Here's the procedure I am:
Launch HP Printer Utility
I chose my printer from the list
I go to the Support tab
Update firmware
InternetExplorer window opens (it runs for 4 5sec, and it makes me open the page was canceled)
I connected via USB, I have no Ethernet interface.
Test: I tried it with Internet Explorer (v.9.0.8112) and Google Chrome (v. 24.0.1312.57)
I tested on another PC - same problem except that the plant IE "closing innatendue software"
I did the windows update
I updated the Remote TeamViewer on my client PC (requires remote), can this cause the problem?
If you have a solution I suggested?
Thank you in advance
Update firmware
