Hi,
I'm repairing HP Designjet 500.
I replaced the carriage belt, everything looks make OK, but when the service station initializing, it bumps to left edge side then goes to opposite side and bumps to the right side.
Then error 21:10 was displayed.
I tried almost everything, but once when I entered to service menu, I try to "reset to default settings"
It started normally work (no bumps to the edges), but then sadly some cartridges were empty and it wants to replace the old cartridges with the new one, because it couldn't initialize the startup test.
Then I switch off the plotter, turn it on and sadly error 21:10 was displayed again.
I tried to initialize default setting again, but after this, error 21:10 is still here since.
Please, have you any ideas how can I solve this problem?
Would be very, very appreciated.
Thanks.
Thanks.
