HP M551 ERROR 98.00.01
  • SOS
    • Oct 2011
    • 46
    Hello,
    hp-m551 error 98.00.01, can anyone know how to fix problem?
  • JustManuals
    • Jan 2006
    • 9865
    Re: HP M551 ERROR 98.00.01
    Corrupt data in the firmware. You need to reload the firmware. You should be able to get it off the HP website.
    HtH
    Paul@justmanuals.com
    • Barış KURT
      • Jul 2010
      • 68
      98.00.01 Corrupt data in firmware volume
      Description
      Data corruption has occurred in the firmware volume
      Recommended action
      Turn the product off, and then on.
      Use the Clean Disk item in the Preboot menu.
      Reload the firmware.
      Black is Kyocera , Color is Gestetner.
