HP LJ P4014 - paper bent
  • spree
    • Jun 2012
    • 211
    Hello,
    I have problem with HP LJ P4014DN.
    The every third, fourth, fifth paper picked from Tray 2 (500 sheet cassette) is bent over the top and scratched.
    The text is also skewed (probably paper goes skewed into toner) - see attached pictures:
    When Tray 1 is used, it works without problems.
    I've cleaned rollers on registration assy with acetone.
    I've changed in Tray 2: 2x pick-up rollers, 1x separation roller, 1x torque limiter and still is bending over and scratching.
    Please, have you any suggestions what to do?
    Thank you very much.
  • walterman
    • 196
    Re: HP LJ P4014 - paper bent
    Are the maintenance items/kits up to date? Judging from the looks of that page, you may need to start there, first. Send a pdf of the maintenance page.
    • theengel
      • Nov 2011
      • 1784
      Sometimes the tray1 moves slower than plain paper tray 2... so it might not actually be tray specific. Could still be fuser or other things. But I would take a look at the solenoids throughout the paper path and make sure they're not sticking.
      • walterman
        • 196
        It looks like feed/ seperation issue. I have replaced the sep pad assembly to resolve similar issues from tray 2, also look for bent guides in the paper path from tray 2 into the registration area. I have found labels stuck in that section
        • spree
          • Jun 2012
          • 211
          Fuser have 148.731 pages printed.
          Tray 2 have 147.779 pages printed.
          But probably it isn't a bad fuser, because the text is skewed, so probably the paper is just under the toner in wrong position.
          • Wild Bill
            • Jul 2005
            • 774
            check the spring on the jam lever (Green) on the wrap around section or tray 1 assembly under toner cartridge. It breaks and causes similar problems. Just lift on green lever if it has no tension its broke.
            Izzy
            • MBT
              • Aug 2010
              • 51
              It's possible there is some paper stuck somewhere in the path somewhere that it's only intermittently causing problems.
              You can unscrew the registration assemby, lift it up some, blow some air in there.
              Also it's possible there is paper or something else a problem behind tray 1. It's a few steps to get behind tray 1, but nothing horrible. Just follow the instructions to replace tray 1. You can probably just pull it open on the left side and not have to pull the connector out if you're careful. But if it's the first time, it's best to go by the manual.
              • subaro
                • Oct 2010
                • 1273
                The every third, fourth, fifth paper picked from Tray 2 (500 sheet cassette) [ from original post ]
                OK, so when the third page has been picked up from tray 2, and is being feed, open the top cover when you think the page has reached half way before the drum. this is called the stop test. open the machine and look at the page and see if the page is being nicked. if so, then the fuser, drum and reg assemby is eliminated. now you would be looking at the feed roller assy, which i suspect your problem is. you have to do a bit of disassemby and look for glue, paper stuck ect.
                Also, acetone is a good cleaner, for paint and print shops, but for laser printers i do not recommend using it. is a very harsh chemical i would stay away from using it to clean rollers.
                • allan
                  RTFM!!
                  • 5459
                  Listen to walterman i think he speaks of wisdom. It clearly gets messed up before registration please rule out the fuser.
                  mabe not a separation issue, if the separation was the causing that i thing the paper would of stay in the tray.
                  Start a print and stop it if you think its just out of the tray and inspect. I'll take a piece of hardboard and push it thru the paper path the clear out all kinds of things.
                  Whatever
                  • Elmtech
                    • Nov 2013
                    • 155
                    Also worth checking the rear stop on tray is set for correct paper size and check the torque limiter on the cassette it may be tight.
                    • subaro
                      • Oct 2010
                      • 1273
                      Good point there about the paper stop. that is built in now as every machine i look at, first thing is check paper trays width and lenght adujsters. I think he said he replaced the torque limiter.
                      I don't work too much on hp anymore, but i know i have seen that paper tear in the pics he posted ,but just can't recall what was the fix. My train of thought though is that the paper is probably curled a bit, so when the paper is picked up and fed to the feed roller, it just catches the center of the paper, it bends a little and still feed.
                      I Think also there are two problems, that paper cut and a skew. they are separate problems. I have seen the feed assy bushings completely gummed up where it does not turn. that brings in another issue of lubrication. If the feed assy rollers are smooth and shiny as it sometimes get, skewing can start there even before reaching the registration assy.
                      So, he has to remove the covers and inspect and clean and lube. a page count should give some hints.
                      • spree
                        • Jun 2012
                        • 211
                        I've posted page counts in post before.
                        But it looks like the problem is in paper quality.
                        With another it works properly.
                        • spree
                          • Jun 2012
                          • 211
                          The change of the paper brand looks didn't helped.
                          Do you have any other suggestions?
                          • MattP79
                            Check the paper feed assembly on the leading edge (right after transfer roller) . I had a printer recently where the rollers / spindles on the lead edge had been pushed down. The paper caught on the chassis and curled over in a similar way - simplex mostly OK - duplex jammed badly but similar skew and page curl. If I see a P4015 tomorrow I'll take a picture of what I'm trying to convey.
