HI, Hoping someone can help.
I bought a second hand designjet 500, and I am struggling with the print quality. As the carriage travels across it makes a 'juddering' sound like it is jumping or sticking on something, when I look at the printing it isn't lining up properly, and has over-printed so that the text and lines look blurry.
So far I have: cleaned the service station
Cleaned the white (data cable?) that curls up at the back and the surface it lies on (this was filthy and it got a bit better after)- this seems to hit on the black plastic clips that hold it down when the carriage is 2/3 of the way across should it do this?
Checked the belt for defects/bit stuck in it. The belt looks pretty new, removed a few bits of fluff but nothing major
Checked the pulleys the belt runs on - can't see anything but I haven't taken it totally apart
Cleaned the metal rod it travels on and oiled it with a wee bit of sewing machine oil
Have run a print head alignment and cleaned the print heads
It seems to be worse when it is travelling quickly, but even with the printer set on best and optimised for lines and text it is still doing it. It seems to be worse when printing blocks of colour than when printing just lines and text. I really need it to print my degree drawings!
Any suggestions would be gratefully received
