My customer wants to use this machine to run 110 lb cardstock , I looked for specs and could not get clarity as to whether or not it would likely handle this weight of paper . Contacted LEXMARK , got transferred to the Philippines , still got no clear answer . I had one fellow claim they would handle up to 192 lb paper . Does anyone know this unit ? And/or where to get the specs for what weight of paper it can handle ? My customer desires to use this for presentations . Thanks in advance , Ark .
CS820 does it handle heavy cardstock well ?
Re: CS820 does it handle heavy cardstock well ?
From the datasheet:
Media choices: The CS820 supports a broad media weight range, from 300 70 gsm. You can also use vinyl, labels, cardstock, envelopes and banners, with no media thickness worries. -
It shouldn't be a problem as long as you're setting the proper media type. =^..^=If you'd like a serious answer to your request:
